Uploading a Logo to Simphony
- Select the Enterprise level, click Configuration, and then click Print Logos.
- Insert a new record, and then double-click it to open in form view.
- Click Load Image.
- Select the image, and then click Open to upload it to Simphony. After the logo uploads, an image preview appears.
- Alternately, you can copy the image to your clipboard, and then click Paste Image to upload it to Simphony.
- Click Save.
