Location-Based API Requirements for Simphony Transaction Services Gen 2
The on-premise implementation of STS Gen 2 requires tokens acquired from the Enterprise Back Office (EBO) Open ID Connect (IDM). When creating API accounts for STS Gen 2 in EBO API Account Management, set the Client Scope to either Both or Local. This allows for tokens acquired for that client to be authorized to use the on-premise API. Tokens are valid for only 14 days; it is recommended that tokens are renewed after 7 days, in order to have enough time to authorize a new token before expiry (in the of event of an unforeseen circumstance, such as missing connectivity).
Additionally, on-premise components require initial access to the EBO IDM endpoints in order to acquire authentication related details for workstations running the on-premise API. See the Reporting and Analytics User Guide, specifically the Simphony Transaction Services API topic, for more information.
Since HTTPS is a prerequisite for using the on-premises API, ensure that a valid root certification authority backed TLS certificate is loaded onto all workstations using the on-premises API. The certificate must be loaded in the on-premises certificate folder. The default location is
Simphony/STS/oracle.simphony.sts.onpremise/certificate
.The certificate name must match the host name of the workstation where the on-premises API is running. The extension of the file accepted is pkcs12. Example: hostname.pkcs12.
The default port for the on-premise API is 5443. API paths after the base URL are the same as the cloud endpoints, so cloud documentation can be used if necessary. The API path looks similar to the following example: https://onprem.example.net:5443/api/v1/sample/ABC/locations/biz1.
Parent topic: Transaction Services
