Configuring Menu Item Price and Quantity Override
To configure menu item price override with quantity at the revenue center and employee levels for Transaction Services Gen 1:
  1. Select the revenue center, click Setup, and then click RVC Parameters.
  2. Click the Options tab.
  3. Select 75 - Treat Menu Item Price Override as unit price.
  4. Click Save.
  5. Select the property, click Configuration, and then click Employee Classes.
  6. Double-click the employee.
  7. Click the Operator Options tab.
  8. In the Options column, click the click the ellipsis (...) point button for the revenue center row, select 29 - Treat Menu Item Price Override as unit price, and then click OK.
  9. Click Save.
  10. Select the Enterprise, property, or revenue center, click Configuration, and then click Employee Maintenance.
  11. Search for and select the employee record.
  12. Click the Operator Records sub tab near the lower area of the screen.
  13. In the Options column, click the click the ellipsis (...) point button, select 29 - Treat Menu Item Price Override as unit price, and then click OK.
  14. Click Save.
