The following steps explain how to configure Order Types
for Australian GST.
Select the Enterprise, property, or zone, click Descriptors, and then click Order Types.
Configure two order type records with the following names:
Order Type 1: Dine In
Order Type 2: Takeaway
Click Save.
Select the Enterprise, property, revenue center, or zone,
click Setup, and then click Order
Type Parameters.
Set Dine In and Takeaway as active.
For both order types, click the ellipsis point (...) button in the Tax Mask column,
and then enable the tax.
For the Takeaway order type, click
the ellipsis point (...) button in the Options column, and then enable the option 11 - Forgive Inclusive Tax, alongside other options as
needed.
Click Save.
Simphony uses the label of the first tax rate linked
to the first active order type to print the GST label on guest checks
and customer receipts.
