PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Tax Rates Per Item to Print on Guest Check, Customer
Receipt and Journal
Select the Enterprise, property, revenue center, or zone,
click Setup, and then click Tax
Parameters.
Click the International Options tab.
Select 16 - Print Tax Rate per item to print tax rates associated with the menu item class on the guest
checks and customer receipts. Deselect this option if you do not want
the tax rates to print on the guest check, customer receipt, or journal.
For example, the line item for a Grilled Cheese Sandwich
on the printed check appears as follows:
1 Grilled Cheese 5.99 T2
T4
The guest check and customer receipt indicate the tax
rate applied to each item. The T2 and T4 shown after the item’s price
indicate that tax rates 2 and 4 were applied to a Grilled Cheese.
