PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Workstation Number and Transaction Number to Print
on Guest Check, Customer Receipt, and Journal
Select the Enterprise, property, revenue center, or zone,
click Setup, and then click Format
Parameters.
Click the Options tab.
Select the appropriate workstation and transaction options.
54 - Print Workstation Number: Select
this option to print the workstation number on the header of guest
checks and customer receipts, and in the journal.
55 - Print Transaction Number: Select
this option to print the transaction number on the header of guest
checks and customer receipts, and in the journal. The journal header
does not contain the legacy transaction number (labeled TRN).
