Delivery Connectors
This section explains how to set up delivery service providers—using the Delivery Connector 24.3 UI— to connect to Simphony. If you are using Delivery Connector 21.8 or earlier to connect to Simphony, see Oracle Simphony Delivery Connector Legacy Configuration for more information.
Delivery Connectors is a delivery platform integration management tool within Simphony Home that allows you to add, modify, and delete delivery platform integrations in your Simphony Cloud Service point-of-sale (POS) solution.
The following delivery service providers are supported:
  • Deliveroo
  • DoorDash
  • Rappi
  • Skip The Dishes
  • Uber Eats/Postmates
Conversational Ordering is not supported with delivery service provider integrations.
