Disable Delivery Service Provider
If you no longer use a delivery service provider, you need to disable the interface for the platform that is not in use.
  1. Access Delivery Connectors from Simphony Home.
  2. Navigate to the location.
  3. Click the ellipsis (…) adjacent to the location, and then select Deactivate Connection.
