Assigning Default Condiments to Parent Menu Items
Default condiments are used for the following purposes:
  1. The default assembly of a menu item (for example, a hamburger comes with tomato, onion, and pickle)
  2. Breaking down a menu item to the ingredient level for inventory system integration (for example, the default number of pickles that accompany a hamburger)
Default condiments are not supported with Transaction Services. If you are using Transaction Services, workstation operators need to add default condiments separately.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
  2. Search for and double-click the parent menu item record.
  3. Click the Default Condiments subtab, and then click Add.
  4. Click the ellipsis point (...) button in the Condiment Set column, select the condiment set, and then click OK.
  5. (Optional) Enter the sort number for the condiment set in the Sort Group column.
    Condiment sets appear on checks, receipts, SLUs, and KDS displays according to the Sort Group. Condiment sets in Sort Group 0 appear first, followed by 1, 2, and so on. Items that have the same Sort Group number appear as they are listed in the EMC.
  6. To display the default condiments, click the ellipsis point (...) button in the Options column, and then select 1 - Display when in default state.
  7. To charge guests for the condiment count, select 2 - Charge for entire sales count, and then click OK.
    For example, if a hamburger comes with two slices of cheese by default, the guest is charged regardless of whether they order one or two slices of cheese on the hamburger. If you do not select this option, guests are only charged when the condiment count exceeds the default count.
  8. Click Save.
