Condiment Prefixes
Prefixes change the state of a condiment. Many restaurants allow workstation operators to modify menu items, such as adding, removing, increasing and decreasing the number of condiments on the item. Operators can add prefixes (for example, No, Add, Extra) that appear before the condiment on the guest check, order devices, and customer receipts. This provides helpful preparation instructions to the kitchen staff and eliminates order confusion.
Condiment prefixes use the same print class as the condiment they are modifying.
