Creating Menu Item Classes for Prefixes
  1. Select the Enterprise level, click Descriptors, and then click Condiment Group Names.
  2. In the Text field, enter a group name to appear in the POS client for the condiment prefixes.
  3. Click Save.
  4. Select the Enterprise level, click Configuration, and then click Menu Item Classes.
  5. Insert a prefix record (for example, Add).
  6. Double-click the new record.
  7. On the General tab, select the Condiment Prefix Type.
    Table 17-14 Condiment Prefix Types
    Condiment Prefix Type Description
    1 - Description Prefix
    Describes the condiment it modifies (for example, Lite Mayo).
    2 - No Prefix
    Removes the default condiment (for example, No Cheddar).
    3 - Add Prefix
    Adds a non-default condiment (for example, Add American).
    4 - Sub Prefix
    Replaces a default condiment with a similar condiment (for example, Sub Swiss).
    5 - Plain Prefix
    Removes condiments from the menu item.
    6 - Reset Prefix
    Resets the menu item with default condiments.
    7 - Clear Prefix
    Removes multiple condiments from the menu item.
  8. Click the Options tab, and then select 2 - ON = Condiment Menu Items; OFF = Regular Menu Items.
  9. Click the Condiments Group tab.
  10. In the Member Condiment Groups section, select the condiment group that you created in Step 2.
  11. Click Save.
  12. Repeat Steps 5 through 11 to configure menu item classes for the remaining prefixes.
