Configure Menu Items
Delivery service provider integrations do not support conversational ordering.
Enhanced condiment prefixes are supported in delivery service provider integrations. The Add, No, and Descriptor prefixes configured for tagged menu items sync to delivery service providers. If there is more than one default condiment set for a parent menu item, the system ignores the default condiments after the first one. See Condiments and Condiment Prefixes for more information.
When using Skip, enhanced prefixes are not supported with priced condiments. Skip does not allow No condiment prefixes to have negative prices unless at least one descriptor prefix is configured and enabled. If there is no descriptor prefix enabled, subtractive pricing won't apply and menu items retain their price.
After creating menu items, add condiments to the items that need them, and then follow these steps:
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
  2. Search in the master records, and then select the menu item from the list.
  3. Update and assign a SLU to the menu item.
    1. Click the General subtab.
    2. In the Touchscreen Properties section, select the relevant SLU from the drop-down lists in SLU through SLU 8.
      You can assign up to eight SLUs per menu item. The SLU number specifies the order in which SLUs appear on the delivery provider ordering site (from least to greatest number). For example, a menu item assigned to SLU 2 will appear in the Entrees category:
      1 Starters
      2 Entrees
      3 Desserts
    3. Click Save.
  4. If necessary, update the menu item prices.
    1. Click the Prices subtab.
    2. Set the menu item price in the Price column.
      If the menu item has multiple prices associated with different menu levels, ensure that each level has an appropriate prefix configured. See Setting Main, Sub, and Custom Menu Levels for more information.
    3. Click Save.
  5. Specify the menu item name, item description, and image the customer sees when ordering through the delivery application.
    1. Click the Images subtab.
    2. Enter or change the Consumer Item Name.
    3. Enter or change the Consumer Item Description.
    4. In the Image 1 section, click Upload to select the image and upload it to Simphony.
    5. (Optional) Enter or change the image Title.
    6. (Optional) Enter or change the image Comments.
    7. Enter the URL that links to the image.
    8. Click Save.
  6. When using Skip, you have the option to include allergen information for a menu item on the delivery service provider application.
    2. In the Allergen Class Override field, click Select, select the allergen class, and then click OK.
    3. Click Save.
  7. Change the availability status of a menu item to generate a notification through the delivery application, advising Skip of the menu item’s new status (unavailable or available). These updates are immediately sent to Skip and will update in near real time.
  8. To arrange menu items in the Skip UI using a sort order priority:
    1. Select the Enterprise, click Configuration, and then click Data Extensions.
    2. Insert a new record for the delivery platform menu item sort priority.
    3. Configure the fields for the new Data Extension.
      Table 14-15 Delivery Platform Sort Priority Data Extension
      Field Details
      Table
      Select Menu Item Definition
      Extra Column Name
      Enter DeliveryPlatformSortPriority
      Type
      Select 2 - Number
      Data Constraints
      Select the Range 0 -999999999.
      Sort Priority
      Not applicable; use the default value of 0
      Display Width
      Enter 150
      Translatable Name
      Translatable Help
    4. Click Save.
    5. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
    6. In the Search Criteria section, select Menu Item Definition from the Record Type drop-down list, and then click Search. Double-click the desired record to open it to Form view.
    7. Click the Definition List tab, and then in the DeliveryPlatformSortPriority column (far right), enter a number to indicate the order in which this menu item will be displayed in the Skip UI.
      For example, enter 1 to denote items that are displayed first in their category in the Skip UI. You can enter 2, 3, and so on for each menu item to indicate the display order.
    8. Click Save.
  9. To exclude combo group items or condiments from syncing to Skip:
    2. Insert a new record for delivery platform combo group item exclusion.
      Table 14-16 Exclude From Delivery Platforms Data Extension
      Field Details
      Table
      Extra Column Name
      Enter ExcludeFromDeliveryPlatforms
      Type
      Select 4 - Boolean
      Data Constraints
      Not applicable
      Sort Priority
      Display Width
      Enter 150
      Translatable Name
      Translatable Help
    4. Click Save.
    7. Click the Definition List tab, and then select the checkbox in the ExcludeFromDeliveryPlatforms column (far right).
      When ExcludeFromDeliveryPlatforms is checked, the combo group item does not appear in the Skip UI.
    8. Click Save.
