Exporting an Extensibility Package
Extension Application developers can export an existing Extension Application to a package. The exported data is not intended to be a complete package; it contains a text file (todo.txt) with instructions.
Encrypted DLLs and encrypted SIM scripts cannot be exported.
To export a package:
- Select the Enterprise, property, revenue center, or zone, click Setup, and then click Extension Application.
- Select the new extension application content, and then click Export to Package.
- Select the folder in which to save the package.
- Click Save.
Parent topic: Import/Export Extensibility Packages
