Importing an Extensibility Package
By importing an extensibility package into the EMC, Extension Application content and Configuration Content defined in the package's manifest.xml and metadata.xml files are created automatically without manual steps required by the user. This includes the creation of zonable keys and their respective settings, and the associated content types such as binary (that is, DLL, Image, or Icon) or string (that is, Loose Xaml, Resource Dictionary, Python, Resource, CSS, Javascript or Text).
After a package is imported, text that the package author has included (and details of files mentioned in the metadata.xml) are located on the Content tab.
To import a package:
Parent topic: Import/Export Extensibility Packages
