Insert Content: Simphony_DiscountBundle
Ensure the newly created record is highlighted, click Insert Application Content button, and then enter the text shown below in the following fields:
ZoneableKey = Simphony_DiscountBundle
Description = Application
Click OK.
Figure 15-3 Extension Application Module - Insert Application Content Window
From the Content Type drop-down list, select 3 - DLL, and then click the Import from a file link.
Figure 15-4 Extension Application Module - Content Type Selection
Navigate to the Simphony_DiscountBundle.dll file from the installation package, select the file, and then click Open.
Figure 15-5 Importing the Simphony_DiscountBundle.dll Package
Click the General tab and then enter Simphony_DiscountBundle.dll as the Disk File Name.
Figure 15-6 Extension Application Module - Disk File Name Entry
If necessary, scroll to the right, click the ellipsis symbol (...) under the Target column, and then select 1 - Win32 and 14 - Linux only. No options bits should be enabled, under the Versions column for the (any) - (any) settings.
Figure 15-7 Extension Application Module - Targeted Workstation Settings
Click OK.
Click Save.
Parent topic: EMC – Extension Application Installation
