2 CAL Packages
All devices in the Enterprise
Devices in selected properties
Specific devices
Each customer has specific needs to deploy to the Enterprise, property, or specific devices. If you are unsure, the safer route is to deploy the CAL packages to the specific devices or property you plan to upgrade.
A typical Simphony installation has a set of pre-defined CAL packages available for deployment. This document provides the basic steps required to complete a successful upgrade. Additional package deployments could be required for custom applications or other features not explicitly reviewed.
CAL Client
Service Host Download
Service Host
CAL Directory and Package Contents
The CAL
Package files and folders are located on the Simphony application
server in the [Drive Letter]:\MICROS\Simphony2\EGatewayService\CAL directory. This is a very important directory. Handlers in this
directory process messages that are sent to the Simphony application
server. The EGatewayService directory includes the encrypted database
information, as well as the web.config file that includes important
Simphony settings. The following table lists the subdirectories that
reside in the EGatewayService\CAL folder and the CAL package contents
for various types of client devices.
Table 2-1 Simphony CAL Packages
| Platform Type | Type of Device | CAL Folder Contents |
Android |
Devices running the Android mobile operating system |
Service Host.19.8 |
WS KDS Display |
Kitchen Display System (KDS) Controllers |
Oracle Linux for MICROS |
Devices running the Oracle Linux for MICROS operating system |
Non-Supported (or not required) CAL Packages
Service Host |
Not Applicable |
A subdirectory is named for the Service Host ID which contains automatically generated setup information for each Service Host. |
Win32 (Microsoft Windows) |
Any Microsoft Windows machine, such as the MICROS Workstation 820 (running Microsoft Windows 10), Oracle MICROS Tablet 700 Series, Oracle MICROS Workstation 6 Series, or the Oracle MICROS Tablet E-Series |
The Simphony application installer imports CAL packages directly into the transaction database during installation. When this installation option is selected, all CAL packages included within a release are copied into the file system before being imported. Each Simphony release could include changes to internal CAL packages and their contents. Refer to the listing below for the specific CAL Package content of prior releases. These links direct you to the Simphony Configuration Guide, where this legacy information resides.
Simphony Release 2.9
Simphony Release 2.10
Simphony Release 18.1
Simphony Release 18.2
More About Platform Types
0 - All Clients
1 - Win32 Server
50 - Win32 Client
69 - Android (can be used for MC 40s running Android)
80 - Linux Client
101 - DTR Controller (KDS Display Controller)
Figure 2-1 CAL Package Configuration Tab
Installation and Upgrade
Name: Identifies the CAL package
Version: Identifies the release version number using a four-number dotted notation format (for example, 2.80.4.25)
Commands: Indicates what, how, and where files are placed
The Simphony installer derives an internal name and version for Simphony packages from the Setup.dat file. The internal name and version typically differs from the package name and version. For example, ServiceHost 2.9 and ServiceHost 2.8 are two separate packages, but they share the same internal name, ServiceHost. The installer identifies the matching internal names and prevents installing and running two versions of ServiceHost.exe on the same client.
The CAL client uses the internal name and version from the Setup.dat file to determine whether to download the CAL package. EMC does not let you configure duplicate schedules for packages with the same internal name. For example, if you have a deployment schedule for ServiceHost.2.8 to deploy to the Enterprise, adding an Enterprise deployment for ServiceHost.2.8 and ServiceHost.2.7 results in the following error message: Cannot save duplicate deployments.
Beginning with Simphony release 2.10, prerequisite software is pre-loaded in a local directory on workstations, rather than downloading the prerequisite software from the Enterprise through CAL. This reduces the time between opening a new workstation and signing in to the Simphony POS client for the first time.
When you upgrade Simphony to a new release, the installer does not add new deployments and does not change existing packages or schedules. As a result, you do not need to change deployment schedules from Install to Skip. The installer preserves CAL packages and adds new release versions.
