PreviousNext
JavaScript must be enabled to correctly display this content
Viewing, Reloading, and Saving CAL Package Contents
Select the Enterprise level, click Setup, and then click CAL Packages.
Highlight the CAL package, and then click the Package Contents tab. The Platforms section lists all
available platform types, the Setup.dat version, and CAL package name.
From the Files list, select a platform
to see all files included in the package.
To open the file in Notepad, click View Selected
File.
To reload the entire CAL package for all platforms and files
from the specified file location, click Reload Package
From Disk. You must be signed on with the same hierarchy
level as the CAL package to see this command.
After you modify
an existing default or custom package, reload the package. Ensure
that the Setup.dat version matches the file before it loads to avoid
reloading the package on all POS clients.
After installation
and when the load balanced address changes, replace the local machine
with the load balanced address in SimphonyInstall.xml, and then reload
the entire package.
To save the entire CAL package for all platforms and files
to the specified file location, click Save Package To Disk, select an empty output folder, and then click OK.
