Check Add/Transfer
Transferring checks is a procedure that changes ownership of a guest check. Simphony allows privileged workstation operators to transfer checks from another server to themselves by employee number or by employee ID number. Guest checks may also be transferred across revenue centers. The Transfer Checks function only transfers the ownership of the guest check; it does not transfer the check’s sales totals for reporting purposes.
Add Check means to combine two checks together while in a transaction.
