Allowing Employees to Add or Transfer Checks
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Double-click the role type record (for example, administrator, manager or server).
  3. Click the Operations tab, and then click the Guest Checks subtab.
  4. Select the appropriate permission options for the user role:
    Table 25-10 Transfer of Check Permissions
    Option Select to allow employees with this role to transfer checks...
    45 - Authorize Transfer of Checks in the Same Revenue Center
    From another operator within the same revenue center.
    46 - Authorize Transfer of Checks Between Revenue Centers
    From another revenue center.
    47 - Authorize Adding of Checks in the Same Revenue Center
    To be in a check, and add another check to it within a revenue center.
    48 - Authorize Adding of Checks Between Revenue Centers
    To be in a check, and add another check to it from another revenue center.
  5. Click Save.
