Custom Browser
With this feature, you add buttons using the Custom Browser function, on touchscreen pages which launch web pages on the workstation. To locate the module, access the EMC, click Setup, and then click Custom Browser (under Custom Content).
Table 26-7 Basic Setup
| Hierarchy Access | Role Access | Role Privileges | Views |
| Enterprise, Location, and Revenue Center | Touchscreens | Custom Browser | View, Edit, Add Override | Table view only |
Figure 26-9 Custom Browser - Table View (only)
Table 26-8 Custom Browser Configuration Settings
| Field Name | Description | Data Type |
| Description | Enter the description of the URL entered. The description
is seen when selecting the URL for a button in Page Design and also
in the URL selection dialog on the client.  Add the required
URL, for example,  | Alphanumeric |
| Protocol | This is either HTTPS, or when selected from the drop-down list, HTTP. The default setting is the HTTPS protocol. | List Choice |
| URL Address | Enter the URL address of the website to be accessed. | Alphanumeric |
| Options | Press the ellipses (...) to show the option. Option 1. Do not display URL in button function. Select to hide URLs from the Select URL dialog. Deselect to show URLs in the Select URL dialog. This option allows you to add hidden URLs to an allow list on the client, so the user can access and navigate to pages which have associated URL's. For example, if the website you set up requires you to login, the login webpage can be set up as a hidden URL so you can have access to the webpage, but not see the URL in the dialog list. | List Choice |
Parent topic: Workstation Touchscreen Pages
