Configuring Macros
A macro is a button that, when pressed, executes a series of commands. Macros save time when workstation operators frequently enter certain sequences or keystrokes. You can set macros to include menu items, service charges, discounts, tenders, function keys, alphanumeric keys, or a link to another macro.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place the macro button.
- On the Edit tab, select the page area in which to define the macro button.
- Click Button to add a button.
- On the General subtab, enter the button name in the Legend field.
- From the Type drop-down list, select Function.
- Click the black arrow directly beneath the Type drop-down list, select the Macro function, and then click OK.
- Click the Edit Macro Keys button, and then add the appropriate steps in the proper sequence.
- Highlight the macro button.
- Position and size the button on the page. Use the Style arrow to change the color.
- Click Save.
Parent topic: Workstation Touchscreen Pages
