Configuring Smart Keys
Smart keys call multiple functions based on a set of conditions. For example, the same key can be configured to start an autofire check if the order channel condition is 'Delivery', and to begin a fast transaction if the order channel condition is 'To Go'.
Smart keys are not supported on hand-held POS devices.- Select the Enterprise, zone, property, or revenue center, click Configuration, and then click Page Design.
- Select the page where the smart key button is to be accessed.
- On the Edit tab, click Button.
- Enter information in the following Page Design fields.
Table 26-4 Page Design Edit Fields
Field Entry Legend
Enter the name of the button.
Type
Select Function from the drop-down list.
Click the black arrow beneath the Type drop-down list, select Smart Key, and then click OK.
- Click the Edit Smart Keys button.
- Click the Add button.
- Enter information in the fields as described in the following
table.
Table 26-5 Smart Key Entry Button 1
Field Smart Key Entry Condition
Select a condition name from the drop-down list.
Value
Enter the object number or numbers for the condition, separated by commas.
Legend
Enter a description for this condition.
Type
Click the black arrow beneath the Type drop-down list, select the function that will be run if this condition is met, and then click OK.
- Click the Add button to add another condition.
table.
Table 26-6 Smart Key Entry Button 2
Value
Legend
Type
- Click the Close button.
- Click Save.
- Configure as many smart key entry buttons as required.
Related Topics
Parent topic: Workstation Touchscreen Pages
