Configuring OPERA Connection
- In the Interfaces module, create
an Interface Record with the following settings:
- In the General tab, set the Interface Type to 6 – OPERA Connection.
- In the Options tab, set the following:
Name
This field is pre-populated with the System Name details and is not able to be changed
Auth Schema
Select the schema from the drop-down list (SSD or OCIM)
Enterprise ID
Enter the Enterprise ID (OCIM only)
Scope
Enter the Scope (OCIM only)
App Key
Enter the App key
Client ID
Enter the Client ID (OCIM only)
Client Secret
Enter the Client Secret (OCIM only)
User ID
Enter the User ID (SSD only)
Password
Enter the Password (SSD only)
URL
Enter the URL
For more information on how to obtain these details, see the Oracle Hospitality Integration Platform documentation.
- In the Properties tab, select the property/properties where the Connection will be enabled.
- In the Properties Parameters module,
configure the OPERA Property Parameters. For each property selected
in the prior step, you must configure one or more OPERA property parameters.
- In the General tab under the OPERA Property Parameters section, set the following:
OPERA Connection
Select the OPERA Connection from the drop-down list
Hotel/Resort ID
Enter the Hotel or Resort ID for the OPERA PropertyNote:
The Hotel or Resort ID is case sensitive, and needs to be capitalized.Currency Code
Select the Currency Code for the base currency of the OPERA property
Cashier ID
Enter the Cashier ID for this OPERA property
Posting Type
Select Sales Itemizers to post sales to OPERA by Sales Itemizers, or Family Groups to post sales by Family Groups
External System
Enter the name of the External System in OPERA
- In the Options tab, select option 65 – Activate OPERA Connection. This step is required for clients to obtain security tokens and for non-room charge transactions to be posted to OPERA. It is recommended to complete the remaining steps prior to activating the connection.
- In the RVC Parameters module, enable the OPERA Connection in the Interfaces tab. The OPERA PMS Interface must be enabled for each revenue center that uses OPERA.
- In the Tender/Media module:
- Configure Room Charge Tender(s) by selecting the interface link
that corresponds with the OPERA Connection.
Do not select the interface link for self-pay tenders. - Configure General Ledger Tenders to post to OPERA:
General Ledger Tenders are tenders for which payment has already been obtained, such as cash or card payments. These transactions are usually posted to OPERA for record keeping. In OPERA PMS, the transactions are posted to Payment Master (PM) accounts, which are represented with generic room numbers.-
In the General tab, enter the OPERA PM Account for the tender.
In the Interface Options tab, select the Interface link that corresponds with the OPERA Connection.
- In the Page Design module, configure
the following buttons:
- Add a Room Charge button to the
touchscreen with the following settings:
Type
Payment Tenders (select the tender created in Step 4a)
Payment Type
Cash:Cash
- Add a Guest Lookup button to
the touchscreen with the following setting:
Type
Pms Inquire (select the corresponding Interface link)
Parent topic: OPERA Connection
