Prerequisites and Assumptions
The table below is used to track the various prerequisites and assumptions that have been made with this development.
| Category | Description |
Compatibility |
The solution is used with Simphony 19.4 or later. This application is available for Simphony clients running on the Microsoft Windows® or Oracle Linux for MICROS operating systems. This application is not supported on Android, macOS, or other operating systems. Menu items that have prompts (for example, Required Condiments) are not supported by this feature. |
Setup |
Configuration of all Simphony settings, including Page Design and nutritional and allergen information, is a manual process. Specific instructions regarding design elements are not included in this document. The implementor of this solution must design and configure screens and buttons based on property and cosmetic preferences. |
Parent topic: Configuring Discount Bundles
