Configuration
Setup Overview
  1. Unzip the installation files.
  2. Setup the Extension Application and configure the interface settings.
  3. Add the Data Extension.
  4. Create discounts according to the required specifications.
  5. Configure the Data Extension.
  6. Update the database and restart each Simphony workstation (ServiceHost).
  7. Test all applicable use cases and verify the setup.
