Creating Buttons for Conversational Ordering
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place menu item master buttons.
- On the Edit tab, select the page area in which to define the menu items (including condiments) (typically the transaction area).
- Click Button to add a button.
- On the General subtab, select the appropriate function from the Type drop-down list.
- Click the black arrow beneath the Type drop-down list.
- Position and size the button on the page. Use the Style arrow to change the color.
- In the Legend field, enter the button name.
- Click Save.
- Repeat these steps to create buttons for each of the menu item master names.
Parent topic: Conversational Ordering
