Setting Enhanced Condiment Prefixes Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes. Double-click the menu item class. Click the Options tab. Select 65 - Support Enhanced Prefix Mode (Parent Only), and then click OK. See Configuring Menu Item Classes and Assigning Condiments to Parent Menu Item Classes for more information. Click Save. Parent topic: Condiment Prefixes
