Configuring Touchscreen Buttons for Condiment Prefixes
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Locate the Combo/Condiment Orderer and deselect Allowed.
- Click Save.
- Insert a new button on the transaction screen, select Menu Item as the button type, and then select a prefix as the menu item (for example, Add).
- Enter or generate a legend for the button, and then click Save.
- Repeat Steps 4 and 5 to configure touchscreen buttons for the remaining condiment prefixes.
Parent topic: Condiment Prefixes
