Setting the Condiment Display
  1. Select the Enterprise, property, or revenue center, click Setup, and then click Format Parameters.
  2. Click the Options tab, and then select the appropriate options:
    Table 17-14 Condiment Display Options on Checks, Receipts, and POS Client
    Option Description
    35 - Hide Previous Round Condiments on Display
    Hide previous round condiments and show only the parent menu item when a workstation operator picks up a check.
    45 - Sort Current Round Condiments on Screen
    Condiment sorting occurs only when items are in different print groups and the parent allows condiment sorting.
    Set the check detail area to sort condiments as they are added.
  3. Click Save.
  4. Select the Enterprise, property, or revenue center, click Setup, and then click Control Parameters.
  5. To allow condiments to be added out of order (conversational ordering), click the Options tab, and then select 44 - Permit Required Condiments To Be Entered Out Of Order.
  6. Click Save.
  7. Select the revenue center, click Setup, and then click Order Devices.
  8. Double-click a printer record, and then click the Options tab.
  9. To print condiments in red font, select 10 - Print Condiments in Red (Overrides Print Class Settings).
    The printer must be capable of printing in red.
  10. Click Save.
