Configure Menu Items
Delivery service provider integrations do not support conversational ordering.
Enhanced condiment prefixes are supported in delivery service provider integrations. The Add, No, and Descriptor prefixes configured for tagged menu items sync to delivery service providers. If there is more than one default condiment set for a parent menu item, the system ignores the default condiments after the first one. When enhanced prefixes are used with priced condiments, the price is rolled up to the parent item; when No prefixes are used with priced condiments, the priced condiment amount is subtracted from the parent item. See Condiments and Condiment Prefixes for more information.
After creating menu items, add condiments to the items that need them, and then follow these steps:
- Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
- Search in the master records, and then select the menu item from the list.
- Update and assign a SLU to the menu item.
- If necessary, update the menu item prices.
- Specify the menu item name, item description, and image
the customer sees when ordering through the delivery application.
- When using Deliveroo, you have the option to include allergen
information for a menu item on the delivery service provider application.
- Click the General subtab.
- In the Allergen Class Override field, click Select, select the allergen class, and then click OK.
- Click Save.
- Change the availability status of a menu item to generate a notification through the delivery application, advising Deliveroo of the menu item’s new status (unavailable or available). These updates are immediately sent to Deliveroo and will update in near real time.
- To arrange menu items in the Deliveroo UI using a sort
order priority:
- To exclude combo group items or condiments from syncing
to Deliveroo:
Parent topic: Deliveroo
