Deliveroo
Decide on your menu. Deliveroo supports one menu.
Decide on a unique tag name for the menu.
Plan the list of menu items.
Determine menu availability. For example, will the menu be available only on weekdays between specific times?
The menu can have multiple categories but must have at least one category. A category is a group of similar menu items. For example, you can have a lunch menu with categories for salads, sandwiches, and desserts.
In Simphony, a category corresponds to a SLU. Each category needs its own SLU.
Deliveroo supports a maximum of 100 SLUs. -
Decide on an image to display for the menu. This is required. You can upload the menu image to the Oracle Object Store through a dummy menu item.
Consider the following characteristics of each menu item:
Customer-facing menu item name
Deliveroo menu sync does not accept menu item names which contain fewer than two characters. This can cause issues when using the Chinese language. -
Customer-facing menu item description
Menu item image that meets the following specifications:
JPEG or PNG file format
Pixel size of 1920 x 1080
Aspect ratio of 16:9
Menu item price
Allergen classes
Consider the display of menu items on delivery platform ordering sites and kiosks, and determine whether the following are needed:
Price sequence level filter
Condiment group filter
Image slot
SLU slot
- Register with Deliveroo
- Configure Workstations
- Create Tender Media
- Create Order Types
- Configure Open Discount
- Create Deliveroo Employee
- Configure Currency Settings
- Configure Language Culture
- Creating Allergen Classes
- Create Menu Tags
- Menu Item Screen Lookup (SLU)
- Configure Menu Items
- Configure Combo Meals
- Sign In to Simphony Home
- View Delivery Connector Status
- Add Delivery Connector
- Verify Setup
Parent topic: Delivery Connectors
