Create Tender Media
You need to create a dedicated tender record for each delivery service provider. These tender records are used when posting delivery service provider orders. The tenders can be set up to process online orders.
- In the EMC, select the Enterprise or property, click Configuration, and then click Tender/Media.
- Insert a tender record for each food delivery order, enter the name (for example, DeliverooAccount, DoorDashAccount, RappiAccount, SkipAccount, UberEatsAccount, PostmatesAccount, and so on), and then click OK.
- Double-click the record to open it.
- On the General tab, select 1 - Payment from the Key Type drop-down list.
- Click the Options tab, and then click the Ops Behavior subtab.
- Select 3 - Assume Paid in Full.
- Click Save.
Parent topic: Deliveroo
Parent topic: DoorDash
Parent topic: Rappi
Parent topic: Skip
Parent topic: Uber Eats/Postmates
