Sign In to Simphony Home
You can access Delivery Connectors from Simphony Home. To access Simphony Home, use the URL that was provided by Oracle. If you are unable to locate your Simphony Home URL (OpenID Provder URL), it’s located in the EMC Enterprise Parameters module, Applications subtab.
When copying this URL for access to Simphony Home, exclude the /oidc-provider/ portion of the URL.
  1. To access Delivery Connectors, navigate to Simphony Home, enter your Email or User Name, Enterprise Name, and Password, and then click Sign In.
    Figure 14-12 Simphony Home Sign In Page
    This figure shows the Simphony Home Sign In page.
    If you have forgotten the password, click Can’t Sign In to initiate an email with a time expiration link that allows you to set a new password.
  2. To open Delivery Connectors, click the application navigation icon This image shows the Simphony Home application navigation icon or hamburger icon. at the top left of the Reports page.
    Figure 14-13 Simphony Reports Page
    This figure shows the Simphony Reports page including the icon used to access Delivery Connectors.
  3. Select Configuration and Content in the side menu.
    Figure 14-14 Side Menu Access to Configuration and Content
    This figure shows the Side Menu access to Configuration and Content.
  4. Click the Delivery Connectors tile.
    Figure 14-15 Delivery Connectors Tile
    This figure shows the Delivery Connectors Tile within Configuration and Content.
