PreviousNext
JavaScript must be enabled to correctly display this content
Allowing Employees to Begin Waste Checks and Run Waste Reports
Select the Enterprise level, click Configuration, and then click Roles.
Select the role type, and then click the Operations tab.
To allow employees associated with this role to begin waste
checks and to authorize other employees to begin waste checks, select 263 - Authorize/Begin Menu Item Waste Check.
Select the appropriate report privileges as described in
the following table:
Table 22-2 Menu Item Waste Report Privileges
Privilege Name
Allows the Employee to ...
31062 - Run Employee Waste Report
Run the Employee Waste Report from the workstation.
31063 - Run Menu Item Waste Report
Run the Menu Item Waste Report from the workstation.
31064 - Run Waste Summary Report
Run the Waste Summary Report from the workstation.
