Configuring Waste Reasons Select the Enterprise level, click Descriptors, and then click Void/Return/Waste Reasons. To add a new waste reason, enter a waste reason in an empty row of the Text column, and then select 2 - Use for Waste in the Options column. To use an existing void or return reason as a waste reason, select 2 - Use for Waste in the Options column adjacent to the void or return reason. The options work independently of each other; you can set one, both, or none. Click Save. Parent topic: Menu Item Waste
