Configuring Order Channels to Appear on POS Workstation Devices and Reports
You can configure an order channel to appear on Property and Employee Financial Reports
  1. To control the appearance of an order channel on the POS and in the workstation Journal Report:
    1. Select the Enterprise or property, click Setup, and then click Format Parameters.
    2. Click the Options tab.
    3. To show the order channel name on POS pages and in the POS Journal reports, select 65 - Display Order Channel on Workstation.
      The order channel appears as text in the guest check header, and in the check header on the POS Journal reports.
    4. Click Save.
  2. To configure an order channel to appear on Property, Employee, and Revenue Center Financial Reports:
    1. Select the Enterprise or property, click Setup, and then click Report Parameters.
    3. To enable printing the order channel section on financial reports, select 12 - Print Order Channel Breakdown on Financial Reports.
    4. Click Save.
