EMC – Configure the Data Extensions
Navigate to proper hierarchy node in the locations tree, click Configuration, and then click [under Sales] Discounts.
Double-click on the desired discount and switch to form view.
From the Data Extensions tab, select DiscountBundle.
Configure DiscountBundleItems as a comma-separated list of menu item object numbers for the menu items to be added to the check before the discount is applied.
Figure 15-10 Data Extensions
Save your changes.
The discount bundle extension application works with a coupon (manually enabled Automatic Discounts) only.
As with the standard configuration setup, all discounts should be tested prior to the enabling of the data extension to ensure they apply to the specified menu items.
See Discounts for configuration instructions.
Parent topic: Configuring Discount Bundles
