EMC – Create the Data Extensions
Data Extensions are required by the plug-in to identify the discounts for which this feature should be enabled, as well as a field to hold the list of menu items that are added when the discount is applied to a check.
  1. Select the enterprise level in the location tree. Navigate to Configuration and then click [Reporting and Data] Data Extensions.
  2. Insert a new record.
    Figure 15-8 Extension Application Module - Insert Record
    This figure shows the extension application module when inserting a new record.
  3. Configure the fields for the new Data Extensions.
    Table 15-4 Discount Bundle
    Field Details
    Table
    Select 67 - Discount
    Extra Column Name
    Enter DiscountBundle
    Type
    Select 4 - Boolean
    Data Constraints
    Not applicable
    Sort Priority
    Not applicable; use the default value
    Display Width
    Enter 150
    Translatable Name
    Translatable Help
  4. Insert a new record.
    Figure 15-9 Extension Application Module - Insert Record
  5. Configure the fields for the new Data Extensions.
    Table 15-5 DiscountBundleItems
    Field Details
    Table
    Extra Column Name
    Enter DiscountBundleItems
    Type
    Select 0 - Text
    Data Constraints
    Max Chars: 1024
    Sort Priority
    Display Width
    Enter 150
    Translatable Name
    Translatable Help
