PreviousNext
JavaScript must be enabled to correctly display this content
Configuring a KDS Display to Run on the Same Client as a Workstation
Select the property, click Setup, and then click KDS Displays.
Double-click a KDS Display record to open it.
Click the Layout tab, and then configure
the following settings:
From Top: Enter how far from the top,
in pixels, to place the KDS window on the workstation screen.
From Left: Enter how far from the left,
Click the General tab, scroll to
the Options section, and then select 11 - Always Hide Frame.
Enabling this option hides the KDS Display window frame when
the KDS Display UI is not in full-screen mode.
Click Save.
Add the Show OPS function to the
KDS toolbar to allow workstation operators to switch focus back to
the POS client. See Configuring the KDS Toolbar for instructions.
