Consumer Routing Hardware
Given the scale of the implementation, it is likely that enterprise-grade network hardware is being used rather than consumer-grade equipment.
There will be minimal existing infrastructure related to firewalls,
LAN, and proxies.
This setup is likely unsuitable for larger installations.
Security is likely provided solely through NAT.
The customer will likely require additional support to understand their network.
Parent topic: Special Property Considerations
