VLAN and VPN
A Virtual Local Area Network (VLAN) is a group of devices on one or more local area networks (LANs) that are configured to communicate with each other at the data link layer, as if they were on the same physical network. All devices within a VLAN share the same broadcast domain and communicate using their MAC addresses.
VLANs provide a way to segment a network based on end-user needs, such as access to specific resources and services, and are not restricted to a single physical location. A VLAN can span a single floor or multiple buildings. Communication within a VLAN is based on logical, rather than physical, connections.
Switches are used to segment the network by assigning specific ports to particular VLANs. Each device on a VLAN connects to the switch through a cable plugged into its assigned port.
The benefits of VLAN include:
  • Enabling the logical grouping of devices, even if they are located across multiple physical sites
  • Minimizing the need for additional routers, thereby reducing deployment costs
  • Simplifying network administration
  • Facilitating easy control and segmentation of broadcast traffic
A VLAN does not provide inherent end-to-end security.
A Virtual Private Network (VPN) is a technology that securely extends a private network over a public network, such as the Internet, and is commonly used to provide remote access to a company’s network resources. VPNs create a secure, virtual tunnel between your device and the destination—whether that is a website, company resources, or a customer site. This tunnel encrypts all traffic passing through it, hides your real IP address, and enables access to content as if you were on the private network. Depending on the protocols used, a VPN can operate at either the data link layer or the network layer.
There are two types of VPNs:
  1. Client-to-Site (Remote Access): This type of VPN allows remote users to connect to the network as needed, providing secure access to company resources from any location.
  2. Site-to-Site: This type of VPN connects entire networks to each other, allowing specific machines on different networks to communicate continuously without requiring separate setup for each connection.
The benefits of VPNs include:
  • Providing a high level of security through encryption
  • Ensuring privacy and confidentiality of data
  • Enhancing the overall efficiency of network access, especially for remote users
  • Supporting anonymous file sharing, including use with peer-to-peer (P2P) networks
The disadvantages of VPNs include:
  • Higher costs due to the need for specialized equipment, such as VPN concentrators and routers
  • Increased administrative overhead, as managing VPNs requires more advanced knowledge and experience with security protocols
