Wi-Fi Considerations by Property Type
Wi-Fi-Reliant Property
Businesses that depend on wireless technology typically have a higher ratio of wireless to wired devices and are operationally more dependent on Wi-Fi for nearly all aspects of their business.
Potential impacts for this property type include:
  • Increased demand on wireless bandwidth due to the large number of active wireless devices.
  • Reliance on wireless technology for both internal and external communications.
  • A high number of concurrent client connections.
Key considerations:
  • Ensure sufficient bandwidth allocation.
  • Minimize latency.
  • Utilize robust WLAN hardware and reliable wireless technology.
Wi-Fi-Regulated Property (Airport)
Businesses operating in large infrastructures—such as airports, government institutions, and hospitals—must adhere to strict wireless guidelines. This environment may have the following impacts:
  • IP address and subnet ranges are restricted.
  • Multiple subnets are assigned to hardware devices.
  • A greater number of broadcasting access points is likely.
  • No control over access point SSID broadcasts.
  • Higher number of shared access points.
  • Network access is restricted.
  • MAC address filtering may be implemented for security purposes.
  • More concurrent clients are connected per access point.
  • A higher number of SSIDs are broadcasted per access point.
  • The POS SSID broadcast may be hidden.
Key considerations:
  • More rigorous testing may be required.
  • POS devices are more likely to experience client congestion.
  • System testing is limited due to security restrictions.
  • Access to systems and network infrastructure may be limited.
Wi-Fi-Challenged Location (Cruise Ship)
The placement of access points on cruise ships may be limited by internal structures and the use of heavy materials, which can negatively affect wireless coverage and performance. Complex structural designs can lead to increased wireless interference, and some areas may have insufficient wireless coverage, resulting in connection blackouts. As a result, offline mode occurs more frequently in these environments.
Key considerations:
  • The check sharing process may be disrupted by frequent offline occurrences.
  • POS devices may require robust recovery processes when returning online.
  • Communication can be frequently interrupted.
  • Complete communication blackouts are possible.
  • Communication issues may lead to financial discrepancies.
