Multiple Subnets
Due to the building’s size or layout, the IP ranges assigned to workstations may be divided across multiple separate subnets.
If correct routing is not implemented when traversing subnets, Simphony on-premises components will not communicate properly. Bi-directional subnet traffic must be allowed to ensure reliable communication between components.
Parent topic: Special Property Considerations
