Accessibility Settings
Accessibility features in the EMC support users who use high-contrast display settings or keyboard navigation.
High-contrast display settings
Enable a contrast theme in Windows before opening the EMC.
  1. For Windows 11:
    1. From the desktop, click Start.
    2. Go to Settings, Accessibility, and then Contrast Themes.
    3. Select a theme from the Contrast Themes list, and then click Apply.
  2. For Windows 10:
    2. In the search box, enter high contrast settings, and then select High contrast.
    3. Select a theme from the Choose a theme list, and then click Apply.
Navigating the home page with a keyboard
  1. To move focus to the Location panel, press Ctrl+H.
  2. To expand an Enterprise or property level and show its locations, press the right arrow key.
  3. To move through locations in the hierarchy, press the up arrow key or down arrow key.
  4. To open a module:
    1. Press Ctrl+T to move focus to the tabs, and then press the up arrow key or down arrow key to move between tabs.
    2. Press Tab to move to the first focusable element in the tab.
    3. Press Tab to move through the modules in the tab.
    4. Press Enter to open the module.
Keyboard shortcuts
The EMC supports standard Microsoft Windows keyboard shortcuts and application-specific shortcuts. Use the following table to navigate and work in the EMC without a mouse.
Table 3-3 General keystrokes
Keyboard Shortcut Result
Tab
Navigates to the next focusable field or element from top to bottom and left to right.
Down Arrow
Varies based on context:
  • In the Home Page location hierarchy, moves one item downward.
  • In a table, moves to the next row.
  • In a drop-down list, moves to the next item.
Up Arrow
  • In the Home Page location hierarchy, moves one item upward.
  • In a table, moves to the previous row.
  • In a drop-down list, moves to the previous item.
Right Arrow
  • In a table, moves to the next column on the right.
  • In the Home Page location hierarchy, expands a location to show its properties or revenue centers.
Left Arrow
  • In a table, moves to the next column on the left.
  • In the Home Page location hierarchy, collapses the list and moves focus to the parent location.
Delete
Deletes the selected record.
Enter
Triggers the activity when focus is on a link or button.
Insert
Adds a new record.
Alt+E
Accesses the Edit menu on the toolbar.
Alt+F
Accesses the File menu on the toolbar.
Alt+H
Accesses the Help menu on the toolbar.
Alt+V
Accesses the Table or Form view menu, where applicable, on the toolbar.
Ctrl+C
In Table view, copies the selected record or records.
Ctrl+F
Opens the Find dialog, where you can search for records by entering search criteria.
Ctrl+G
Opens the Go To Record dialog, where you can go to a record by entering its object number.
Ctrl+H
In the Home Page, moves focus to the location hierarchy.
Ctrl+K
Closes all open modules, including the Home Page, and disconnects from the EMC.
Ctrl+O
Opens the EMC Login page when disconnected from the EMC.
Ctrl+P
Prints records in Table view.
Ctrl+Q
Closes the active module.
Ctrl+S
Saves changes.
Ctrl+T
  • In the Home Page, moves focus to the main tabs.
  • In Table view, shows or hides the record filters.
Ctrl+V
In Table view, pastes copied records.
Shift+F10
In Table view, opens the right-click menu when focus is on a record.
F3/F4
In Table view, allows you to copy and paste fields.
F3 copies the cell content and moves to the cell in the next row. F4 pastes the content and moves to the cell in the next row. You can continue to press F4 to paste the same information into multiple cells in the same column.
F8
Opens the EMC Record Translation dialog.
