Deleting Configuration Data and Open Checks
Simphony 19.10 and higher allows operators to continue working with transactions containing the following deleted configuration data.
Menu Item Masters
Menu Item Definitions
Menu Item Prices
Menu Item Classes
Discounts
Service Charges
Tender/Media
Employees
Operators
For the purpose of this table, a "deleted menu item" means an item that is made non-orderable by deleting its master, definition, price, or class.
| Operation | Allowed | Comments |
Void deleted menu item |
Yes |
Repeat round |
No |
This function is disabled if there are any deleted menu items. |
Touch reorder deleted menu item |
No |
Copy deleted menu item |
No |
Update deleted menu item count |
No |
Split off deleted menu item |
No |
Auto combo |
No |
Deleted menu items are excluded. |
Uncombo item |
No |
Neither deleted combo meal items nor combo meals containing deleted menu items can be uncombo'd. |
Add menu items |
Yes |
Deleted menu items are not available for additional ordering, even if they are already on the check. |
Service Total |
Yes |
Apply Payment Tender |
Yes |
Split Check |
Yes |
Deleted item cannot be moved to another check. |
Touch edit check |
Yes |
Tax exempt check |
Yes |
Tax exempt item |
Yes |
Add check |
Yes |
Void closed check |
Yes |
Adjust closed check |
No |
This operation is prevented if there is any deleted configuration data. |
Reopen closed check |
No |
Auto service charges |
Yes |
Auto discounts |
Yes |
Discounts apply if the menu item is deleted, but not if the discount definition is deleted. If an auto discount is permanently applied, it remains after the discount definition is deleted. |
Check transfer across revenue centers |
Yes |
Checks can be transferred to revenue centers that do not contain all the definitions. Items that do not exist in the destination revenue center are treated as if deleted. |
Parent topic: Enterprise Management Console
