Configuring Login Options
Configure multi-factor authentication (MFA) and the idle time limit for EMC sign-ins. When the idle time limit is reached, EMC locks. Users must enter their user name and password to unlock EMC and resume using it.
  1. Select the Enterprise level, click Setup, click Enterprise Parameters, and then click the Login tab.
  2. In the Multi-Factor Authentication section, enable Email One-Time Password.
    To use the Can't Sign In link for a forgotten EMC password, configure an email server.
  3. In the Email Configuration section, select the Primary SMTP Server subtab and enter the required settings.
    Table 3-2 Primary and Backup SMTP server fields
    Field Description
    Server
    Enter the IPv4 address or name of the Primary SMTP server. Click Select to choose an email provider, and then click OK. Selecting a provider populates the Server field with its SMTP server name.
    Port
    Enter a port number or use the default.
    SSL
    Select to enable a secure connection using HTTPS.
    User Name
    Enter a user name for access to the Primary SMTP server.
    Password
    Enter a password for access to the Primary SMTP server, and re-enter it in Confirm Password.
    Source Email
    Enter the email address used as the sender of OTP emails.
    (Optional) Name
    Enter an alternate sender name for the Source Email address.
  4. Select the Backup SMTP Server subtab and enter the Backup SMTP server name or IP address.
  5. Enter the required Backup SMTP Server settings using the fields in the table.
  6. On the Primary SMTP Server subtab, click Send Test Email to confirm the SMTP server configuration and delivery of an OTP email. Repeat this step on the Backup SMTP Server subtab.
  7. In the Maximum Idle Time in Minutes field, enter the maximum number of minutes EMC can remain idle before it locks.
    Enter a value from 1 through 480 minutes. If you enter 0, EMC uses the default of 15 minutes. Values greater than 480 are set to 480 minutes.
  8. Click Save.
