Audit Trail Purging
For privileged users, the Purge tab is visible in the Audit Trail module. This tab is visible when the Audit Trail is opened from the Enterprise and the signed in employee is associated with an Enterprise Role with the option, Purge Audit Trail, enabled. From this tab, the signed in employee can remove old records from the Audit Trail table in the database.
In addition to this manually initiated purge, the Data Transfer Service (DTS) purges Audit Trail records automatically.
Purge records
To manually remove records, select the date through which records are purged, and then click Purge. For example, if you select October 30, 2020, Audit Trail deletes records dated October 30 and earlier.
Records are deleted based on the UTC date of the Audit Trail record.
