Using Audit This Record
Use Audit This Record to view the audit history for one or more records in a module. This option is available in almost every module.
Audit record results
When you select Audit This Record, the Audit Record tab opens. Its grid is similar to the Audit Trail Search Results grid, but it omits the property, revenue center, and Module columns because those values are the same for every selected record. The Comments column is always hidden.
The Object Number column does not appear for modules without object numbers, such as RVC Parameters. The Application column appears only when the record can be edited outside EMC.
Module-specific availability
In Employee Maintenance and Menu Item Maintenance, you can access Audit This Record only from the Table View right-click menu.
Audit all records
To audit all records in a Table View or Form View module:
  1. Click the upper-left cell of the Table View grid.
  2. From the Edit menu, select Audit This Record.
  3. When prompted to retrieve Audit Trail information for all activity in the module, click Yes.
This prompt also appears when the module contains no records or when all records are filtered out of view.
  1. Select the Enterprise or property, and then open a module that contains at least one record.
  2. Select one or more records, right-click inside the first column, and then select Audit This Record for one record or Audit Selected Records for multiple records.
    Alternatively, from the EMC toolbar, click Edit, and then select Audit This Record.
  3. To run specific queries on the selected record or records, click the Show Advanced Options link.
    The Run Search button retrieves records from the database; it does not filter the records currently displayed in the Table View.
  4. Use the Audit Trail search parameters to define the query. See Audit Trail Search Parameters for more information.
