Optional CAPS Configuration Tasks
CAPS Optimization for High Loads
To handle high transaction CAPS environments, system administrators can enable threaded posting. To enable threaded posting on all CAPS types, modify the Simphony web.config.txt file located on the CAPS machine.
For Simphony 19.x users, the following key needs to be manually
entered in the appSettings section:
<add key="MaxMrequestPlaybackThreads" value="x" />
In the syntax provided in the example above, x represents the number of threads.
The number of threads used depends on the volume of Mrequest messages. Also, the number of connections is derived from the number of threads. Under enough load, the value sets the upper limit of threads. There is a point when adding connections decreases performance. As such, if you have a posting backlog on CAPS, it is suggested to configure 1 thread for every 25 workstations as an initial value and adjust as needed based on the available CAPS hardware resources.
CAL Installation Prerequisites for a Workstation without POS Operations (CAPS Only Workstation)
Configure a service host for CAPS.
Set the CAL deployment schedule. See Configuring the Deployment Schedule to Install CAL on a Workstation without POS Operations for instructions.
- Select the Enterprise, click Setup, and then click CAL Packages.
- For Simphony version 2.9 and Simphony version 2.9.1:
- If the CAPS workstation is running Microsoft Windows Embedded POSReady 2009, select Service Host Prereqs from the left pane.
- If the CAPS workstation is running Microsoft Windows 7 or later, select Service Host Prereqs (SQL 2012) from the left pane.
- For Simphony version 2.9.2, select Service Host Prereqs from the left pane for all workstations.
- Click the Deployment Schedule tab, and then click Add Deployment.
- From the Deployment Type column, select 2 - Specific Service Host.
- In the Service Host column, click the ellipsis (...) point button, select the CAPS workstation, and then click OK.
- In the Action To Take column, select 0 - Install, and then click Save.
- Select Service Host from the left pane, and then repeat Steps 4 through 7.
Scheduling a Reload Check and Posting Database
You can schedule a full reload of the Check and Posting (CAPS) database for a property. Data in the CAPS workstation database will be deleted and replaced with new data when the reload is run, so access to the option needs to be restricted to support users only. (In the Roles module Actions tab, enable the Tasks action only for the support user role.)
CAPS being offline when database synchronization changes have been purged
When a reload cannot be run from the front end (such as for CAPS running as a Service on a client)
When the Enterprise Egateway and CAPS are not on the same LAN or VPN
The Reload Check and Posting Database function is performed once on the next restart of CAPS. This task is not repeated during each startup.
- Select the property, click Tasks, and then click Tasks.
- Click the Reload Check and Posting Database button, and then click OK to confirm. The Reload Database dialog shows the status as Pending or Idle, which indicates the status of the reload database task. The default value is Idle (not scheduled).
- To cancel a pending operation, click the button again and confirm the cancellation.
