Employee Levels
Each employee in Simphony is associated with an Employee Level, which is configured in the EMC's Employee Maintenance module or via the Property Management Console (PMC). The Employee Level is a layer of security; it controls how employees interact with other employees by preventing some employees from accessing other employee records. It also gives EMC users access to some employee roles, but not others.
Configuration
The Employee Level allows a one-digit entry, where 0 offers an employee the most access and 9 offers the employee the least access. The Employee Level controls access to other employee records in the EMC and PMC, but the functionality is slightly different.
PMC and EMC Usage
In the EMC's Employee Maintenance module, if the Employee Level of the signed in user is not 0, the list of Employee Levels is restricted to only levels that a user may access. For example, if the signed in employee's level is 2, the drop-down list shows 3-9.
Employee Level Setting is 0
When the Employee Level for an employee is set to 0, the functionality is the same for both the EMC and PMC. Employees at this setting can view all other employees including themselves.
Employee Level Setting is non-0: EMC
Employee A's Employee Level is set at 2
Employee A logs into EMC and enters Employee Maintenance
Employee A can see all employees at levels 3–9
Employee A cannot see employees at levels 0–2, including himself
Because the employee cannot see himself, there is no way to change his level or other privileges.
PMC Security Setting is non-0: PMC
Employee A opens the PMC enters the employee procedure
Employee A cannot see employees at levels 0–2. However, the employee can see himself, with access to only these fields:
First Name
Last Name
Check Name
Revenue Center
Assign ID
Assign Mag Card
Increment Shift
Because the employee cannot change their own level, there is no way for this employee to view additional employees.
